I have the most infuriating problem, with basic soldering, which for the life of me I cannot understand. I've asked this before but I need a new fresh take on it. I have had this same thing for over 20 years I'd say/ I have -never- found the cause.
The problem I have is so fundamental I am embarrassed when it happens, embarrassed to ask, embarrassed considering I've built (& sold for good money too) entire amps, including a complicated Twin Reverb rebuild entirely from scratch. So it has nothing to do with soldering technique itself, whatsoever.
But today.. I cannot undo one wire. From a switch terminal. Impossible. Ages spent holding the iron onto the old solder but will not melt. It only singes the solder. Similarly, I practise (I mean the very shame of it) soldering a wire to a lug. The solder takes ages to flow, then just "balls" of it drop off the tip, instead of being able to quickly tin the tip. 5 minutes holding the flaming solder onto the tip. But it will barely melt. So I cannot solder a wire to a lug.
So the thing is -not- that I cannot solder. Once I have an iron -that works- I'm off & running, one solder then another on on on.
But I come up against this infernal brick wall, time & time again. Solder iron, to solder iron. Every single one I've bought has ground to a halt.. because of this infernal issue. So I buy another, it works for a while.. then brick wall. I buy an expensive temp controlled one.. exactly the same, the brick wall problem again (so a more expensive one, is no diifferent frtom a cheap one- I have to bin all of them). It is costing me a fortune.
One day I convince myself its A) a temp thing/ has to be/ so why isnt enough temp getting to tip? the next day I convince myself its B) the coating on the tip.. must have gone, or been replaced with I dont know 'oxidisation'?. The next day I get so demoralised I convince myself C) it must be my technique (but it cannot be- it's definitely something to do with the iron... not me). The next day it's D) the inferior iron, or the tips.
But unless I can establish what the f**king hell is going on, I am prevented from even replacing 1 wire on a switch. Let alone building a simple circuit with a few components. Totally & utterly impossibility at the moment to undo 1 solder, with a decent temp controlled soldering iron station. I could spend 3 hours holding this iron on the solder, mysolder sucker ready next to it, but it will NOT melt.
Please someone help me. SC
