Ok.... some updates....
One Part 3 of 3 of the Schematic, the Power Amplifier Section, I see an error in the Tube/Voltage table. For V3, Pin 8, it shows 3.3 volts. On Page 10 of the Service Manual, V3, Pin 8, it shows 174 volts. I measure 165 volts.
Next, the Service Manual calls for replacing the 1K ohm resistor on V6b Pin 8 with a 1.8K ohm. That mod was done on this amp.
I am using the instructions and table found on page 10 of the Service Manual. It calls for the following:
V1, Pin 1, using 1khz signal, adjust input to .4vrms – got that.
At V1, Pin 6, I should expect 5 vrms. I am only getting 3.25 vrms.
The goal is to see 11vrms at V3, Pin 11.
So with V1 having less ac on Pin 6 ss expected, everything down the line will be less than expected. I have tried 3 different tubes here and checked the dc voltages. So it must be something around V1 that is contributing to the low volume issue. I’ll lift each of the resistors and caps to check them.
Regarding Leo's comment...
I guess you could do that but I do not believe that was done on the T50C. So for now, I will leave that one alone as I seem to have an issue before the 5M6.
Originally posted by Leo_Gnardo
View Post
