Gibson GSS-100 noise and pops
  • Gibson GSS-100 noise and pops
    I have a GSS100 that has had a complete cap and resistor update
    Overall it works fine but has a couple of issues.
    1 - Persistent hum. May be just part of the design after I added a 3 prong AC cord. Worse with Reverb turned up
    I was thinking of adding isolated Input jacks and having a dedicated signal ground.
    2 - "spitting" noise - random from the system. No specific control or cause. Appears to be from the power amp since it occurs with either pre-amp chain. The main Power Supply caps are new as are the ones
    3 - Pops - loud., But it seems to be only with the "Rock - n - Roll" switch in the Off position. Turning the Tremolo knob from Vibrato to Tremolo creates a very large pop. Turning the amp off/on creates a typical "solid-state" pop. But none of this occurs if the RnR switch is On. It seems like there is a ground issue or "floating" voltage when the Vibrato Board is cut out of the signal path.
    I've attached the schematics of the affected boards - I have the "B" model set.
    Any ideas would be helpful.
