Summer Fund Drive:C'mon guys lets show some support! If this site has helped you an you haven't recently donated Include your username so I know whos donatingPlease consider making a donation. :)
Blue = Neutral.
Blu/Wh and Blck connect together.
Blck/White = Live.
REMOVE C21 and connect earth wire, from your new mains lead, to chassis for your own safety!
Blue = Neutral.
Blck/White = Live.
Thanks! So, the schematic is wrong in the description on the bottom that says "connect BLK wire to BLU wire for 240v operation"... that's what I've thought.
The pilot light is fitted across the relevant primary tapping and will still be on the same tapping and receive the same voltage, as does the fan (if fitted).
