The link doesn't recognize the attachment. At least it doesn't for me.
late 70s AC30 master volume mod
Link took me to EL34world forum, with a thread about MV, and several schematics relevant. At first I saw a register box, but scrolled down to find the material.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostLink took me to EL34world forum, with a thread about MV, and several schematics relevant. At first I saw a register box, but scrolled down to find the material."Take two placebos, works twice as well." Enzo
The EL84 datasheet specifies a max grid leak of 1M with cathode bias, makes 500k for 2 tubes in parallel.
So I would use a dual 1M or 500k pot and 470k safety resistors with an AC30.Last edited by Helmholtz; 04-29-2022, 10:22 PM.- Own Opinions Only -
This is what I was talking about before. The difference between the fixed loads and pots can certainly be tempered. This just pulled from files I have, but is what I had in mind. Actual PI values not relevant. It's the master dual pot values and grid leaks I'm considering.
- Likes 1
Okay.
I decided to go simple route and try replacing 0,047uF cap on the CUT with a wire.
Amp looks like it has been recapped at some point (some elements)
I don't see anything attached to the (500k) cut potentiometer... Also the brown and black wire goes to 1M resistor (blue squared). Can't raise that plate more without resoldering every point from the top and bottom. So, where's exaclty the point I need to jump?
I think what you are calling "1M resistor (blue squared)" is probably the .047 cut cap.
But you say both wires from pot are connecting to it? That is not what schematic shows.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
You were right about it being a cap... Unsoldered it and yes. 1TD mark but it's a 47nf cap. I cut it and placed a wire instead. Yes, it works, but kidn of limited range like on the scale of 10, on 1,5 turn I have full throttle...
Now, questions is, this is A500k pot there, should I got to 1M, or to the other side, 50k for example?
I would replace the pot with a pot+resistor. Measure the resistance at the point where you have maximum volume 1.5/10 by your reckoning and select the nearest value pot of that resistance. Subtract the resistance reading from 500K and insert a fixed resistor of that value in series with the pot (to replace the original cap). Now when the pot is at 10, it will give the same overall resistance as your original setup at 1.5.
You may be able to add a parallel resistor to your existing pot (from the capacitor-side lug to the wiper) to change the value, though this also alters the taper. You still need the series resistor, though.
Originally posted by Mick Bailey View PostI would replace the pot with a pot+resistor. Measure the resistance at the point where you have maximum volume 1.5/10 by your reckoning and select the nearest value pot of that resistance. Subtract the resistance reading from 500K and insert a fixed resistor of that value in series with the pot (to replace the original cap). Now when the pot is at 10, it will give the same overall resistance as your original setup at 1.5.
But isn't it the same/close as using 100k ok 50k pot, for example?
I've tried 1M now and it's even worse...
The pot is wired as a variable resistance and without the cap it acts as a variable load to the PI.
So the lower its resistance, the less output.
If it's a log pot (schematic specifies 250k log), it makes a difference to which end the wiper is connected.
So it might be a solution to connect the wiper to the other end.
Using a 250k pot should be no problem. Lower values might reduce full output power.- Own Opinions Only -
Originally posted by boroman View PostBut isn't it the same/close as using 100k ok 50k pot, for example?
