Turned on my 2019 Shiva 20th Anniversary this weekend & got no output. Plugged straight in, disconnected pedals from effects loop, still nothing. I checked both fuses for continuity & both tested ok. All preamp tubes are lit, but the KT88's won't light up & remain cold. Speaker cab & cable are both fine & it's always been connected to a cab. I'd appreciate any thoughts or guesses on what the problem might be before I take it to a tech. This is my favorite amp & it's never been used outside my home since I bought it new. Thanks!
Bogner 20th Anniv Shiva KT88 output tubes won't light
And did you remove the fuses individually to test them with an ohm meter? If you try to test a heater fuse while it is in the clip, the false path will fool your meter.Education is what you're left with after you have forgotten what you have learned.
Remove the KT88's and measure the heater resistance (between pins 2 & 7) on each. Should be a low resistance.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostRemove the KT88's and measure the heater resistance (between pins 2 & 7) on each. Should be a low resistance.
- Likes 1
Does your amp have the 'half-power' switch? This removes two of the four power tubes in the output stage. Might be an issue with that switch/circuitry.Last edited by nevetslab; 04-26-2022, 05:01 AM.Logic is an organized way of going wrong with confidence
Originally posted by nevetslab View Post
Heater resistance is typically 0.62 ohms, as found on the last Ampeg SVT-CL I had to deal with, where one tube's heater pins were open, but it was a solder joint issue within the tube's Pins 2 & 7. I'd doubt you'd ever finding all four power tubes having that problem on this amp. There may be internal fuse that's NOT on a panel...only accessible inside the chassis. Marshall and Vox have placed heater fuses in their chassis' on some products. More likely an open heater fuse inside the amp.
The heaters on the power tubes are dark. Unlikely both tubes have bad heaters. Your power transformer will have two wires - typically heavier wires than the rest - that carry the 6vAC for those heaters. Is there 6vAC between the two? They then likely go to a circuit board, perhaps with a connector. Is that so? Any burnt looking pins there? Are the power tube sockets on a board or hardwired? If on a board, is it separate from the board the transformer is wired to? If so, are the connections between that board and the power tube board or sockets intact? Follow the 6VAC. check any fuses you encounter also. The 6v gets to each step or it doesn't.Education is what you're left with after you have forgotten what you have learned.
Originally posted by nevetslab View PostI'd doubt you'd ever finding all four power tubes having that problem on this amp.
If that were the case, just one bad power tube heater would make them both go dark, and preamp tubes would still be lit.
- Likes 1
Wanted to thank everyone for your feedback & let you know what the solution was. As a couple of people mentioned on here, there is a separate circuit for the power tube heater & I guess the fuse in that circuit was defective. The tech said it didn't appear to be blown, but once he changed it, the amp was good to go. Thanks again
- Likes 2
Or he left the fuse in the holder to check it with an ohm meter. That usually results in the parallel path around through the transformer and the tubes for a low resistance making the fuse appear good.Education is what you're left with after you have forgotten what you have learned.
