Egnator Renegade no filaments
  • Egnator Renegade no filaments
    This amp is blowing the 5A low voltage fuse, F1, all other fuses are fine, power tubes are pulling current.
    I've got no DC filaments on any preamp tubes, no LEDs, no channel switching.
    I've confirmed I've got 16VAC between the two orange wires from the PT, and the PT has already been replaced once in this amp.
    Where do I go from here?
    Something else that's bothersome is that I've only got 40VDC or so before the plate resistors on all the tubes, leading me to believe I have more than 1 issue..
    RENEGADEsch 8-09.pdf
    Check bridge rectifier AC1 for shorts.
      Can I do this accurately with the caps across each diode?
        Yes, as an initial test. If you then measure a short, retest out of circuit.
          The problem is blowing fuses, not just distortion or something. It will be something large. As to removing parts to test, keep this in mind. There is nothing in a circuit that can make a shorted part appear not to be. You can have a part seem to be shorted but not really be. In those cases, if it seems shorted THEN remove it for further tests.
