Laney VH100R problem: when worms up, sound suddenly fades out, then after few seconds or minutes comes back. Keeps repeating. It kind of feels like somebody turns off the Stand By Switch then turns it on again. All preamp and power tubes changed, biased at about 70%. Tubes, cables and guitar problems ruled out. It effects all channels, and both preamp and power amp section, as I sad like somebody turns off and on Stand by switch. Heaters and pilot lites keeps working, sound goes away.. I am looking at page 4 of Schematic, at that Relay 5 and or TS9 could it be any of those?? Any other ideas??
Laney sound fades out, then comes back
Before you go replacing those parts, monitor your B+ see if it drops out when you have the symptoms. Relay 5 and TS9 are part of a delay turn on circuit that switches B+ to the amp. So, see if you still have B+ after the relay when the amp cuts out."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
- Likes 1
Originally posted by Emetal View Postboth preamp and power amp section, as I sad like somebody turns off and on Stand by switch.
Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostSo the problem happens when you put signal in at the 'Power Amp In' jack?
Originally posted by The Dude View PostBefore you go replacing those parts, monitor your B+ see if it drops out when you have the symptoms. Relay 5 and TS9 are part of a delay turn on circuit that switches B+ to the amp. So, see if you still have B+ after the relay when the amp cuts out.
You have checked the send return connectors and the connecting cables within the amplifier, they are reknown to give issues as the contacts heat and expand. Give them a wiggle and your issue will most likely dissapear.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
Originally posted by Jon Snell View PostYou have checked the send return connectors and the connecting cables within the amplifier, they are reknown to give issues as the contacts heat and expand. Give them a wiggle and your issue will most likely dissapear.
Played at home for two and a half hours, heated the amp with the hairdryer, knocked everything with wooden stick, wiggled and shook, voltmeter hooked on B+ for monitoring and nothing happend. Seems that amp must be played at higher volume for this to happen. I will do that over the weekend and post update. In a mean time any guesses are welcome.
Originally posted by g1 View PostDo you have a load resistor you can use instead of a speaker?Last edited by Emetal; 05-12-2022, 06:52 PM.
- Likes 2
The series lamp acts as a compressor. Its resistance increases with applied voltage.
With 12V across the lamp, its nominal resistance is 66R. At low voltage its resistance might be only 10R.
So total load impedance may roughly vary between 6R and 7R.
Problem is that at 100W output the 12V lamp voltage will be considerably exceeded.
Maybe two 12V lamps in series?Last edited by Helmholtz; 05-13-2022, 12:15 AM.- Own Opinions Only -
