Got crazy readings on the can cap, must replace
Supreme (Garnet) Amp
Originally posted by mtlbasslad View Post
DigiKey website drives me crazy - neverless I still don't know which of the 3 iso trans I need. All presuming 'customer' will pay... SheeshOriginally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 1
FYI: You don't need a 3 cap can. You could save money by using separate caps and even more money if you use radials. I would use radial caps and terminal strips. There's usually plenty of room in those older amps."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
- Likes 1
Don't know the fuse rating - 2A in there now. But you are right, bigger one is only $2 more..
- Likes 1
I must say, that really doesn't help us help you. What does "crazy readings" mean? Be specific.
So to do it right I removed the cap can & got these readings - 750uF section reads 865uF, the 2 100uF sections read 112 uF.
As has been pointed out, that is too much for this little amp & rough on the rec tube... but if the can cap wasn't dead, where is the hum coming from?
I will take the good advice & source radial caps & terminal strips... I wonder if I can find those at DigiKey. I'm pretty sure the nearest parts place would have them, but it's 50km away & the price of gas makes it better to order online.
@g1 can you email me the schematic please? I could not print it out from your post, sigh.I'm not old - I'm vintage
Oh, I thought your readings were going to be voltages. 865uf is only about 15% high for 750, not a problem. 750 may be a problem for the rectifier, but the cap itself can easily be that far off. In those days 20% was close tolerance.Education is what you're left with after you have forgotten what you have learned.
- Likes 1
Originally posted by glebert View PostDoes the hum go up and down with the volume? Also, is it 60 or 120 cycle hum? If necessary download an audio spectrum app for your phone.I'm not old - I'm vintage
Originally posted by The Dude View PostFYI: You don't need a 3 cap can. You could save money by using separate caps and even more money if you use radials. I would use radial caps and terminal strips. There's usually plenty of room in those older amps.I'm not old - I'm vintage
Got the parts & installed the ISO trans. The secondary has a 3rd wire called 'static shield' - what do I do with that?
Also the ISO trans secondary is 140V with a 125V input - with no load is that normal?
Now trying to figure out if the connections to the old can cap were in the right place before I install the 3 new caps...I'm not old - I'm vintage
Originally posted by mtlbasslad View PostThe secondary has a 3rd wire called 'static shield' - what do I do with that?
All transformer secondary voltages sag with load. So no-load voltage being higher by around 10% than with rated load is normal.
- Likes 1
Wire the shield to safety ground/earth, typically amp chassis.
All transformer secondary voltages sag with load. So no-load voltage being higher by around 10% than with rated load is normal.I'm not old - I'm vintage
