Hello All,
I'm no electrical engineer but I've got a functional multimeter here and I'd sure appreciate some diagnostic guidance from the experts on this one:
I've got a vintage tube amp with reverb (2-spring Gibbs/Hammond unit) but the sound of the reverb itself isn't real prominent (i.e., it just isn't there), and I'm told by others who own the same model that the reverb effect should be quite obvious (i.e., deep and lush). So, the question becomes whether the problem lies in the pan itself, the driver (a lone 6DR7 tube) or something else unknown.
The reverb pan itself appears to check out just fine with DC resistance at the two input/output terminals reading roughly 170-175 ohms each, but I have no available means to test the 6DR7 driver tube. I would think (??) I should be able to confirm its output by testing the line-in current (in milliamps) at the male RCA connector (i.e., the input to the reverb pan), right? I've researched the topic as best I can and its supposed to yield a reading of just 2mA, but this is where it gets dicey for me . . . .
My multimeter is a Commercial Electric HDM4100 and I'll admit that I'm not completely confident that I've got the probes connected to the proper choice of plug-ins, nor can I find a suitable operator's manual on-line. However, with the two respective input/output RCA connectors disconnected to/from the reverb pan and the amplifier turned 'on', when I ground the black lead to any transformer stud, and I connect the red lead to the male (input) RCA connector leading to the reverb pan, I get a reading of "zero". In other words, it would appear there's no current.
Have I done something wrong here or is my thinking screwed-up? What's the next step?
