I've got this as a project amp. Had EL-34s in it when I got it, I assumed that they had done a conversion from the original 8417s. NOPE! They just stuck them in and let them redplate. Put my bias probe and nearly fainted as the current shot up to something like 150mA for one tube. Plate voltage is supposed to be 500V but don't know how much it came down. Anyway, figured I should probably do something about it. This is cathode biased and had a 125 ohm 10 watt resistor shared between the two output tubes. Put in a 350 ohm resistor, that got the current down to about 95mA. Put in a 470 ohm resistor (highest 10 watter I have currently) and the current is down to 65mA. Still too high but less heart-attack inducing. The cathodes also share a 40uF cap so I can't just separate the tubes and give each their own resistor.
The question is should I try higher resistor values or is this just chasing my tail? I read somewhere about issues with cathode biasing at high plate voltages.
Would there be any advantage to go with something more like a 6550?
BTW, I have no idea what the plate or screen voltages are during operation. Because the power amp gets the mains power from an umbilical from the preamp chassis it is going to pretty unwieldy to arrange it for probing.
This schematic is supposed to be pretty close as far as the power amp, but it shows 200 ohm for the cathode resistor instead of the 125 mine had.
TIA,
Greg
SANO-schematic.pdf
TIA,
Greg
SANO-schematic.pdf
