I came across this little RCE amplifier made in Canada, model G-5. Presumably a 5W amplifier (?) that is only putting out about 0.6W into my 8ohm dummy load.
Attached is the schematic with voltage measurements. Everything seems fine up until the output tube, but swapping that out with a new tube yielded no additional volume. I also replaced the .002uF capacitor that ties the 6V6 Plate to B2, although I have no clue what the purpose of that capacitor is. I also tried a new rectifier tube, wondering maybe all of the amp's voltages were low.. but everything stayed the same.
Seems like it could be a cool little amp.
I've attached a schematic with the voltage measurements and the amplitude of the input signal in different stages.
