Hello - I picked up an older Crate MX120R combo amp that came with two non-original speakers. One was blown and while the other works they both have the foam surrounds and should have never been put into the amp as the foam surrounds get squashed - both sides of the speaker mounting holes have a flat spot and yep that's at least one spot the foam gets squashed for sure. But, moving on...
I'm hoping hoping someone here might own a Crate MX120R and can tell me which speakers they used (impedance, serial/parallel wiring, wattage, maybe model of speaker).
I'm looking for documentation online at the moment, but maybe someone might have a shot of the back of the amp/etc here...
Thanks either way.
Edit:
I found the user manual which states the following.
"EXTERNAL SPEAKER: Use this jack to connect the amplifier to an external speaker. The internal
speaker is disconnected when this jack is used. The minimum impedance for the external speaker is 4 ohms."
The user manual also states.
"Internal Speaker (2) 12” Crate Custom Design, 8 ohm"
and
"Output Power Rating 115 watts RMS @ 5% THD 4 ohms, 120 VAC"
So, being that the internal speaker gets disconnected when the external speaker is plugged in I'm assuming the amp uses two 8 ohm speakers wired in parallel.
And, based on the 115 watts RMS rating and the name MX120R I'll go with Crate pushing it as a 100 watt'ish amp.
But, I'd still like to know just which speaker they had in this amp originally - wattage, wise, etc.
I know it's not real valuable or anything, but hey, why not try to get it as close as possible if I can
Thanks either way.
Edit:
and
