Hi guys. I recently got Gibson GA30 from 1955, quite unusal design not covered in any schematics over the web (well - I can't find it). Around 300 were made in erly 55 and then they switched to different preamp layout.
It makes very loud cracks, and almost any noise you can dream of...
I managed to play some notes while it didn't cracked for a while, and sounded sweet, but now, just after it's started it's going wild.
Tube layout
12AY7
12AY7
12AX7
2 x 6V6
5Y3
1/ It's been worked on, since some supply caps are from 1980s - they had bubbles so I replaced them before I turned the amp on.
2/ Checked all tubes (replaced them for a different set)
3/ Cleaned pots, tube sockets
4/ Removed all three preamp tubes and it's still the same, so the prpoblem is in the power amp section
5/ That old 10uf cap across 6V6 sockets and big 250R resistor below are also good (replaced them for new ones but problem is still there, so I put back originals)
Does anone have drawn connections LAYOUT or detailed schermatics of those mid 50's GA30s? I found only very basic schematics and I am not so pro to "imagine" the rest. I'd better look at untouched one (or a drawn layout) and try to make all the connections the same as they should be.
Tube layout
12AY7
12AY7
12AX7
2 x 6V6
5Y3
