1965 Realistic Carnival 6AQ5 Conversion Ideas
  • #46
    Likely final schematic...
    • #47
      Any idea what kind of light this is? It ties to the mains switch via a 100K resistor (red wire) and the other side (black wire) goes to ground.
      May be a sealed unit?
      Click image for larger version  Name:	light.jpg Views:	0 Size:	483.2 KB ID:	986918 Click image for larger version  Name:	light2.jpg Views:	0 Size:	282.0 KB ID:	986917 Click image for larger version  Name:	light3.jpg Views:	0 Size:	674.8 KB ID:	986919
      • #48
        Neon.
        • #49
          Originally posted by mozz View Post
          Neon.
          I have a few other neon bulbs. None worked. How much VAC is needed to light these? I am seeing about 20 VAC across the red wire (100K R) and black wire (chassis ground).
          Thank you
          • #50
            Most neons i saw have a 100k resistor and will fire at 80v? So maybe it's just bad or the resistor is bad?
            • #51
              The resistor measures good at 101K so it seems to be dropping about 100 VAC.
              I am thinking of using a LED instead such as this one. https://tubedepot.com/products/alpin...al-pilot-light
              Is states you can connect to 120 VAC without a dropping resistor. Do the leads connect to HOT and Ground or HOT and NEUTRAL?
              Thank you
              • #52
                It makes no sense that the lamp connects to chassis ground.
                Rather it should be connected across the PT primary.
                A neon should read open resistance when disconnected from circuit.
                • #53
                  My 3 neon bulbs were all open resistance out of circuit.
                  So maybe I should test the old neon again. I'm not used to dealing with these neon bulbs. Do they all require a higher voltage as Mozz mentioned 80 VAC? I only see about 20 VAC across the bulb base.
                  Perhaps I should test it with a pot instead of the dropping resistor and see if I can get it to turn on.
                  Sometimes I feel like I ask stupid questions but I would rather ask first then make a mistake that takes out a component.
                  Thank you all!
                  • #54
                    Wait. Are you saying the neon should not be connected to chassis ground? Or were you just referring to the LED bulb I was considering?
                    Thank you
                    • #55
                      That 20VAV might be a ghost voltage.
                      A neon "drops" between 60V and 90V, but always requires a large current limiting resistor.
                      If it's actually a neon, lowering the series resistor is not a good idea.
                      It's generally not a good idea to wire anything between mains line and ground.
                      • #56
                        So it turns out the neon bulb is fine. Switching the black wire from ground to PT primary neutral, did the trick.
                        Big thanks again!
                        • #57
                          Added neon bulb to schematic. Please advise if you see any issues. Thank you
