Hi,
I have a Leslie 147 power amp on the bench which supposedly has too low volume and distorts too much. It is normally used with a transistor organ of some kind and usually takes line level signals well according to the user. The amp has been fitted with a tele connection at some point instead of the original 6-pin connector
I think the hammond tone wheel organs that this Leslie was designed for has a quite hot output: 4 to 6 Volts peak to peak.
The amp has a "console load resistor" switch which was set at 16 Ohms. After switching this to "open" it sounds a bit louder. I tried hooking up a guitar through a preamp and it was now quite ok, but I'm not sure if it should be even louder.
I found this guide what voltages to check:
https://bentonelectronics.com/servic...147-amplifier/
Schematic is here:
Most voltages were higher then they should according to the schematic
Voltages tested:
(Voltages from schematic or above guide in parentheses)
Cathode voltage for 6650 tubes
150 Ohm Resistor to ground 28.8V (25V)
Power supply
Rectifier, before choke 473V (430V)
After choke 457V (420)
Regulator
After OC3 regulator 341V (310V)
After 10k 1W resistor 297V (260V)
Plate and Screen voltages on 6650 tubes
Plate voltage pin 3 of 6650 tube 443V (415V)
Pin 3 to 4 on 6650 tube 110V (105V)
The standout issue was this:
12AT7 plate voltages (should be 115V and maximum 10V difference according to service guide linked above)
Plate voltage pin 1: 200 V
Plate voltage pin 6: 135 V
200-135 = 65V differance!
I'm not sure why this is bad and what effects it could have on sound.
Could it be that the plate resistors are beginning to go bad?
Do the other voltages look ok?
If i want to check the amplification level from input to speaker output, how do I do that with a signal generator? What level should I feed and what should I get at the output for it to be considered a functioning amp?
Thanks for your input!
Schematic is here:
Voltages tested:
Power supply
Regulator
