I have a JC120 here that hums quite loudly anytime it is turned on. None of the knobs affect the loudness of the HUMM. I thought got to be filter caps. I checked them in circuit with my Peak meter sayin they were 0uf capacitance / in circuit. I ordered & received new ones 3300Uf 50V. When I got the old ones out they measured good, but put the new ones in anyway. Still hums like crazy. Using the variac I can see it looks like its drawing too much current. But not enough to pop the fuses. So with the o-scope I probed the outputs and on 2 of the legs there is significant saw-tooth even at just 25% variac. Any ideas on how to isolate this and the saw-tooth should that be there on the outputs? What should I see there? The rail volts look correct. Serial #560599
SM_JC-120_11052.pdf
SM_JC-120_11052.pdf
