Hi,
Please I need some help with my fender Pro Reverb
project amp , below I described the malfunction;
Well , the first thing I do is to let the amp get warm using the standby, then I switch the power on and the amp reacts very strange with a lot of nasty intermittent
noise (similar to interferences) , the sound appears and disappears when I touch or hit very lightly the cab of the amp , but after almost 10 minutes everything become normal , the amp sounds normal without noises at any volume and dosen't even
react with noise anymore when lightly hitted .
Any idea of what could be the cause of this ?
thank you , John
thank you , John
