Started modding the fender champion 600 reissue today and am having problems. First thing I did was change the tubes and replace the speaker with a 6" Jensen MOD. Everything was working great at this point. I did a little research on modding the circuit and thought i would give it a go...I decided to follow a mod by a guy that did the mod on his blog. He had good results and seemed to know his stuff so i basically copied his circuit to try to get this little amp to sound better. The first thing i did was try to bypass the tone stack by lifting out R21, R20, R22, and R18. I added a coupling cap with a value of .0047uF 630VDC from top of R18 to bottom of R20. I also replaced C2 with a .022uF 630VDC cap. For the first gain stage (R9) i replaced with a 220 ohm resistor. I then dropped the plate voltage at R11 by replacing with a 16k resistor. At R12 i replaced with a 33k resistor. The guy on the blog instructed to remove three of the large black caps (C7, C5, C6) to reduce some of the filtering. I have not done this yet because I don't have the parts on hand.
Here is the problem: I turned on the amp to see if there was an improvement. The tubes warmed up and i started to test it out. The amp sounded tighter on the bottom end and at first thought it was an improvement. I then realized that the amp was turned almost all the way up and was not very loud at all. The amp on 12 before the mod was much louder. I also noticed a loud low pitch hum/rumble coming from the speaker as soon as the amp heated up. I cannot figure out where i went wrong. Is this rumble and lack of volume from not replacing the three filtering caps or did i screw something else up? Im stumped and was hoping some champ guy out there could help me out.
Here is a picture of the mod...
