Had a blast with the decade box and amp today. Amp is a single channel ab763 no verb/vib with (2) 12ax7s, (2) 6l6wgb, and a 5u4gb. 440pv. I tweaked a few different areas:
1. V1 plate loads - went up to 120K on both and found that the the amp lost some clarity and sparkle, taking on a more rounded tone that the ts wasn't able to correct. I ended up going back to 100K on both sides of v1.
2. PI plate loads - I moved from 100K/82K to 100K/100K, 100K/120K, and 47K/47K - the smaller the value, the thinner the tone. 100K/100K did sound good, but honestly, not enough of a difference to warrant a change. I tried this with both 12ax7s and a 12at7. Ended up back at the original formula with a 12ax7.
The best mods thus are are reducing the PI filter cap to 16UF and the preamp to 10uf. There's no increase in hum, flab, or other artifacts at volume and the touch sensitivity and bloom/envelope are just outstanding.
