Originally posted by J M Fahey
View Post
2015 VOX Ac30c2 service manual
Originally posted by pdf64 View PostThose tone stacks don't look right?
No bass caps,
and the Fender mid cap is shown as 10nF, rather than the regular BF 47nF (22nF on some models).
Itīs a VOX/Gibson GA70/Fender Pro 6G5-6G7 one !!!!
Download TSC http://www.duncanamps.com/tsc/ to view and play with the more usual arrangements.
The only difference between the one I posted above and the TSC one is that TSC includes the .022uF coupling cap inside the Tone Stack and the one I copypasted has it outside the picture, coming from the earlier stage.
But that does not affect EQ at all.
Tom Phillips
Quote Originally Posted by pdf64 View Post
Those tone stacks don't look right?...
I agree. What's the source of those figures Juan?
What I posted:
from VOX showroom (who are suppossed to know about VOX?) http://www.voxshowroom.com/uk/amp/ac30_tb_hood.html
Fender Pro 6G5 or 6G7 tone stack
As you see, that "mystery" tone stack is in fact way more known than most remember.
Important detail: many consider this very clever Tone Stack "a mistake" , plain "wrong", "an error which was mysteriously copypasted without analysis or correction" and similar demeaning designations; the fact is this is VERY CLEVER and you can check what I say by ... ummmm ..... playing with TSC.
Just move the Bass slider 0 to 10 and marvel.
Fact is this is a THREE pot, Bass/Mid/Treble control , where the Bass pot is also the Mid control.
Of course, since one pot (Bass) does the work of two, you can not set them separately, they are linked.
Let me show both pots (look at the schematics above):
* Bass pot: wiper-to-top section.
Its function is to more or less short the Bass Capacitor (.01 or .02uF) .
Fully shorted: minimum (0) Bass
Fully open: as much Bass as possible (10)
* Mid pot: wiper-to-ground
Fully shorted: 10k resistr shorted: no mids (notice Mid notch gets MUCH deeper, as much as 14 dB or so)
Fully open: Mid notch gets less dip, so "maximum Mids"
Please confirm this by playing with TSC Bass pot settings and see how it strongly adjusts Mids too.
But ... but .... isnīt having both controls linked a problem?
Not really.
With control on 5, you have a good balanced amount of Bass and Mids.
On 10: maximum Bass and 0 Mids (wiper shorts it), which gives the impression of even more Bass
On 0: zero Bass (Bass cap fully shorted). ... in principle this would sound unbearably thin BUT ... now "invisible in plain sight" 10k mid setting resistor is free to do its job.
VERY VERY clever and in no way a "lucky mistake" as VOX Showroom calls it.
Leave a comment:
Originally posted by oc disorder View PostSo C2 has a solid state rectifier.. can recall many problems trying to get a decently made tube rectifier as well as possible problems with the filter capacitor load.
Unfortunately the tube rectifier is used as a scapegoat.
Leave a comment:
Originally posted by pdf64 View PostThose tone stacks don't look right?...
Leave a comment:
Just thought this might add some clarification re the C2 version from ultimate guitar.
Code:http://www.ultimate-guitar.com/reviews/guitar_amplifiers/vox/ac30c2
As I understand it purists prefer the character of the tube rectifier with all it's failings ...
Would have thought this would have a far greater effect than any minor variations in tone caps.
Leave a comment:
No bass caps, and the Fender mid cap is shown as 10nF, rather than the regular BF 47nF (22nF on some models).
Leave a comment:
VOX has used the same klunky (but hey, it's *their* version of clunky and an important part of their signature sound) tone control everywhere, since forever and in a thousand amps, specially AC30 , so I very very much doubt they changed values specifically on your model.
So it should be the same as this:
I have seen a 56pF cap in the place of the 47pF one, a very small change, if any (considering caps were 20% tolerance).
As of possible mods: you can't really decrease the 47/56pF one, parasitic cable capacitance must already be close to that value.
Increasing it will make the amp have more high mids and be less chimey, it will cease to be a VOX without actually becoming a Fender or Marshall.
If you decrease the .022 ones you rise bass turnover frequency and probably amp will become more middy and less bassy.
If you increase it the opposite will happen, the amp will be somewhat more hollow sounding, more scooped.
Leave a comment:
The problem is that I don't know the cap values that are on the stock PCB
Leave a comment:
Thank you all for your comments. I did all the mods to date including going with a more vintage feel of the speakers and tubes. The amp sounds amazing as it stands right now. I am in no way knocking the Stock VOX but I am a professional player and I want to take my sound that extra step including going with the woden clone output transformer and the classic JMI spec caps. Here is a forum that Lyle Caldwell posted on the mods that he performed to get the JMI spec in the new ac30 c2.
Vox AC30C2 Mods with Variable Voltage - MyLesPaul.com
Leave a comment:
It's not the values of the caps it is the caps themselves that they used. I want to mod the crapp caps they used and use mojo caps to get a more vintage feel out of the amp
Least important part in sound is capacitor brand and age.
Speakers are 1000000 times more important, difference can easily be heard and measured.
If anything, try to get a couple **old** speakers , same as those used in original VOX amps (which will cost you a few hundred $$$) or some old VOX , which will cost you a few thousand ... but is the real thing.
Leave a comment:
Well, if you know the values, and all you want to do is change the brands of caps in the amp, seems like the new schematic wouldn't be necessary.
Leave a comment:
Originally posted by vioman19 View PostThanks JMF. But that manual is the one that is older and don't match the new amps. It's not the values of the caps it is the caps themselves that they used. I want to mod the crapp caps they used and use mojo caps to get a more vintage feel out of the amp.
Leave a comment:
Leave a comment:
Leave a comment:
