I have a peavey XXX I just acquired and I am trying to do a few mods to it. First I am wanting to change the screen grid resistors in it and bias it with 2 kt88 power tubes. Then I would like to install a mercury magnetics choke in it and be ready to gig with her.
I have done many mods on amps using other people's guides and learned quite a bit but there aren't any clear cut guides on these so I drew up the mods on the schematic and would like to run them past yall to make sure that I am correct in what I am attempting to do.
here are the screen grid resistors. I know I need to change these four 1k5w. I believe if I do that I should be fine to install kt88 tubes and bias. Am I correct in this thinking or is there something I am missing like increasing sweep of the bias pot or something. Currently the amp is running 4 el34 tubes and I would like to use 2 kt88s.
Next is the choke mod.
I believe the choke goes where that resistor is and the. I have to modify the amps standby switch so it won't pop when I switch it on or switch channels. I believe that will be done with this next step.
I believe I have this all correct but I have never done any mods without a guide from someone else so I am trying to make sure I'm not crazy when planning them out myself lol. Thank you in advanced.
