Thanks for your help up front. I am modding my normal Channel clone amp (fender ab763). I have very little volume ( sounds like it’s on three). It’s wired according to the layout (pictured). I have very little experience with this style pot and was hoping someone could fast track me on to wire this mod using a push-pull pot. Thanks dan
I need help wiring a 1ma push-pull volume pot
the dude,
i using a push pull switch. not a separate slider switch and independent 1ma volume pot. because that is what the layout is showing. Clearly
Originally posted by gui_tarzan View PostI have a different question. Why does it look like the Mid pot is grounded on all three leads along with the .047?Last edited by Helmholtz; 09-05-2020, 01:23 PM.- Own Opinions Only -
Originally posted by gui_tarzan View PostIn the original post on this thread.
If the old wiring is to be ignored it should have been removed. It's not that hard.
Do you know what's the purpose of the mod?Last edited by Helmholtz; 09-05-2020, 09:52 PM.- Own Opinions Only -
There are photos in the first post, I don't know where they came from other than Dandrix posted them. I was trying to draw a schematic from that layout but was confused by the light colored wires showing the original connections, but instead of assuming they were left there by mistake I was hoping someone knew for sure that they should have been removed from that layout - or - the creator should have said "don't use the original wiring that is light-colored". I'm simply looking for clarification.
The previous comments weren't directed toward you, they were directed toward whoever drew that layout.Last edited by gui_tarzan; 09-04-2020, 10:29 PM.--Jim
He's like a new set of strings... he just needs to be stretched a bit.
I think I found the source: https://robrobinette.com/AB763_Modif...le_AB763_Mods_
Looks like one of the "Dumble cool mods". Unfortunately no schematic.- Own Opinions Only -
I think this is the confusing drawing. It shows the arrow 'ground' symbol for all lugs of the mid pot.
Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostI think this is the confusing drawing. It shows the arrow 'ground' symbol for all lugs of the mid pot.--Jim
