Originally posted by überfuzz
View Post
LTSpice model for output transformer
It's just a sine wave used as in-signal with big enough amplitude to make the models clip.
I seem to remember that the linear behaviour among tube models is very close. I.e. he, or we, won't see any significant difference in frequency behaviour between the different models in our simulations. In addition to this, I could not really detect any audible difference in clipping behaviour between tube models in audio simulations of my test circuits. So, this boils down to, no it doesn't matter what tube model you use.
Edit
Disclaimer: The lets say, poor, clipping simulation might not be due to the tube models, rather an under the hood feature of LTspice.In this forum everyone is entitled to my opinion.
Originally posted by überfuzz View PostIt's just a sine wave used as in-signal with big enough amplitude to make the models clip.
Hmm... I just had a brief look at my latest build, or rather the spice file, to see how I did set up the OT (normally I use connected coils). Seems I didn't even bother to set the series resistance in the coils..?In this forum everyone is entitled to my opinion.
Originally posted by jazbo8 View PostI see, for small signal analysis such as AC sweep (frequency response), that is indeed the case, but when you push it to the point when the grid begins to conduct, then the SPICE model that you use does make a difference. In any case, this is usually not a too much of a concern for small signal tubes, but for the output tubes, using models with more accurate control grid and screen grid modeling are generally preferred.In this forum everyone is entitled to my opinion.
Has anyone simulated a tube rectified linear power supply?
I haven't been able to find much guidance on the transformer models but I see that Nakabayashi has models for tube rectifiers.
Seems that most of the discussions about transformers and LTSpice focus on the design of switching supplies.
I would like to try to compare tube rectification against semiconductor rectification.
Blencoe emphasises the importance of power supply sag for pentode screen compression and I'd like to try to simulate that in Spice.
Unfortunately the Fender Bandmaster simulation on the Yahoo LTSpice group page doesn't simulate the rectification of AC it just uses a fixed DC voltage source so no power supply sag.
Hank
Originally posted by hkc View PostHas anyone simulated a tube rectified linear power supply?
HankIn this forum everyone is entitled to my opinion.
Originally posted by überfuzz View PostIf you want to now the sag you'll be able to so by simulating the rectifier+filter, but it wont really simulate how it effects the amplifier.
Originally posted by hkc View PostUnfortunately the Fender Bandmaster simulation on the Yahoo LTSpice group page doesn't simulate the rectification of AC it just uses a fixed DC voltage source so no power supply sag.
Hank
Originally posted by jazbo8 View PostMay be I don't understand what you are saying - not sure why you want to wait for things to settle down - that's steady state...In this forum everyone is entitled to my opinion.
Originally posted by überfuzz View PostIf you model a power section it will take about a minute or more for it to settle. Any readings before this will not represent the live amplifier very good. With tube that models the heaters the warm up is even longer.
