Fully agree, that's why I typically use it between double quotes.
Now we're in need of a better term. Any suggestion?
KT88 amp
Yes, that's what I called "saturation voltage" (had seen this English term used somewhere). …
- Likes 1
Leave a comment:
I get that this might be an exercise in theory and a quest for knowledge, but I'd just like to point out that "squeezing out a few more watts" isn't something to be concerned about. A few more watts will be hardly noticeable with respect to SPL. You'd need to double the output power to get even a 3dB increase.
Leave a comment:
Originally posted by pdf64 View PostThe only apparent explanation seems to be that the anode voltage on their Vg1 = 0 curve is a bit higher, thereby reducing the max p-p voltage swing.
It is the voltage drop across the tube at max. signal current.
A tube with an increased saturation voltage has a more rounded plate characteristic and increased plate dissipation at full power.
- Likes 1
Leave a comment:
…As mentioned earlier, you might have somewhat inefficient tubes.
E.g. Prof. Zollner found that Chinese KT66s can produce less output than original GEC types because of higher "saturation" voltage.
Don't know about KT88s, though.
Leave a comment:
Originally posted by g1 View PostMaybe I'm missing the context, but I don't understand this statement. Maximum supply current is determined by the PT, is it not?
For a given B+ the current is solely determined by the load, i.e. the tubes and the PT has no influence. All the PT can do is sag the voltage.Last edited by Helmholtz; 06-25-2021, 01:44 PM.
- Likes 2
Leave a comment:
As your B+ sags by only around 20V at full power, I don't see a supply current problem. Supply current is determined by the tubes, not the PT.
Another question (sorry to ask): Are you sure your screen resistors are actually 47R and not 47k?
So perhaps an OT with lower primary Z would yield more power?
Leave a comment:
Originally posted by hylaphone View PostSo this suggests the bottleneck is either OT losses, or plate supply current?
Leave a comment:
Calculating to 55W.
Using your RMS meter probably is more accurate.
So this suggests the bottleneck is either OT losses, or plate supply current? I'm just trying to figure out what options are left to reach target power, or even to just squeeze out a few more watts.
Leave a comment:
Originally posted by uneumann View Post
You should be able to make up a few watts by increasing the bias voltage (making it more negative).
That allows for more grid swing before grid current clamps the signal.
Nick's calculator doesn't show a difference.
Leave a comment:
Load resistor is 8.2 Ohm.
Measured right at the speaker jack, same 60W before clipping.
So 10% loss of the 70W target is 63W, more or less where I'm at. Does that jive with your estimates?
Do I have any options left to gain 10 clean watts?
Edit: never mind - see below - greater grid swing does not lead to greater output power.Last edited by uneumann; 06-24-2021, 01:55 AM.
Leave a comment:
Leave a comment:
