Ok... where is Stan (km6xz) when I need him!!! With my best fake Russian accent and channeling Captain Marko Ramius of the ballistic missile submarine Red October, "I present you the Russian made Tube Amp RedBear N 602."
This is one of the amps I have in my possession from my friend's estate. I know very little about RedBear, expect that I see the MK 120, MK 60, something called the "Cub", but I have never seen this one or can find anything on the net.
The good news is that the amp is working, passing a signal through both channels, but it appears the output is a bit weak.
At this point in time, I am hesitant to pull this puppy from the case. And here is why....
-I don't want to break anything including tubes that haven't been pulled out, probably ever !!
-This amp uses the Russian made 6N2P tubes, similar to the 12AX7 but the heaters are wired differently?
-I am not sure about the power tubes (as I do not read Russian). But I see something that says 8912? Are these in fact 6L6 or 5881 tube equivalents?
There is a schematic for the Cub Combo so maybe this one is close - http://www.prowessamplifiers.com/sch...ombo_mkx50.pdf
The other thing I am not sure of is the switch on the back - the one that says Series Parallel. Does this have something to do with the Effects Loop? The line makes it look so (see pic).
And the big question (just like they ask on the TV show "Storage Wars"), what is this worth? Again, I cannot find anything about this particular model.
I think I am better off selling it as is and letting the next owner decide if they want the Russian preamp tubes or re-wire for 12AX7's.
Can anyone shed some light on this one?
Thanks, Tom
Thanks, Tom
