Altec 342B Tube Amplifier - What is it good for?
  • #31
    Originally posted by nevetslab View Post
    There are 12 wires on the secondary side of the power xfmr, so make sure ALL of them have been disconnected and isolated. You could be right, which would be a real shame.
    Ok. Physically disconnected all 12 secondary leads. Powering up the primary is like turning on a switch to my light bulb limiter. Bright light, nothing out of the secondaries. I'm sad.
    • #32
      Just for grins, disconnect the primary wires too, and power up. Want to make sure there is not some short on the mains side.
      • #33
        Ok. I gave that a try but there was nothing left to power up.
        • #34
          Transformer out and opened up.
          • #35
            Just a quick check. Nothing left to power up except the power cord, fuse holder, switch, wires. It won't DO anything, but for example I once found a power toggle switch that had an internal short from one of the contacts to the bushing. That means the mains get grounded to chassis.
            • #36
              Major bummer. Sigh..................
              Well, you can get the xmfr dimensions, mounting foot print, and start searching for a similarly rated transformer. You should be able to find one that has either independent bias winding, or a tap on the HT winding (besides the secondary). Probably will only find single 6.3VAC C/T heater, might also find one with the 5VAC heater for the 5AR4 rectifier tube....though at this point, revising the heater system, perhaps adding a separate small heater xfmr to yield the 12.6VDC heater as was used in the 342B. You could, of course use diode rectifiers in place of the tube rectifier, just to reduce the winding count on the replacement. All is not lost. Just have entered the retrofit realm to restore the mixer to life, less the original Peerless Power Xfmr.
              • #37
                I think I'll put the amp to the side and wait for a Peerless 6192A transformer to show up for sale.
                Deneme bonusu veren siteler
                betticket istanbulbahis
                casinolevant levant casino
