I have a fun one here if anyone is interested in doing some puzzle solving this morning. I'll try to be brief with the facts:
1. This is the 400B/G model
2. Main filters have been replaced as well as the smoothing caps for the 16v rails.
3. Amp has been repaired in the past as it has two new output transistors.
4. I couldn't get many watts out of her but after removing the compression OTA, I get all I want. So this is obviously bad and appears hard to get so it will stay out and the compression disabled.
5. I am unable to find any failed parts. All the transistors, resistors, diodes and zeners check out. The remaining caps test good for ESR.
6. I have disconnected the preamp and ran signal straight into the molex connector with the same result.
7. I have disconnected the finals board and I get the same result.
8. I have replaced the TL074 with the same result.
It sure is an interesting waveform. My conclusion is I have injured drivers and/or VAS from the previous failure/repair. Thoughts? Anything I'm missing?
Schematic = Free download Peavey 400BG Power Module Schematic (audioservicemanuals.com)
