I am working on a mid 90's Fender BXR (Bass eXtended Range) amplifier. When I initially power on the amp it very dimly lights my dim bulb tester (100w bulb).
Usually a solid state amp will flash bright then die down quickly as the reservoir caps charge. The amps usually end up drawing such little current that it does not appear to light the bulb. Not so with this amp. Should I be concerned?
Enclosed is service manual. bxr_200.pdf
