Mystery Randall
  • Mystery Randall
    I have a 1990 randall here..i believe the model is " Hardrock" or " Hardrock Stack" but its not labeled. it came as a mini stack with 2 , 1x12 cabs . Its a mini size head with 2 output transistors, says 50w on the back. The tag inside says model RG 150 Es . but I cant find a schematic for that anywhere online and Randall will not respond .
    It works but has a very burnt resistor . cant see the bands. The resistor is right before the speaker jacks .
    Can anyone tell me whats needed here by looking at the circuit ? I know its a long shot ....but Im at a dead end .
    I drew up the circuit by tracing the pcb when i could get to the bottom Click image for larger version
    I'm guessing it's part of the Zobel network. Probably 10 ohms. Can you post photos of the whole circuit board, both sides?
      . Click image for larger version
ID:	985264 Click image for larger version
        Make sure the 0.1µ series cap is not shorted.
          not shorted .
            Originally posted by Valvehead View Post
            not shorted .
            Then either the power rating of the resistor wasn't sufficient or the amp has a stability/oscillation issue.
              Not sure if this will help but here is a RG 100...similar amp. But mine just has the 2 output transistors and only 1 of the .27/7w
              randall_rg100_sch.pdf
                I can't find anything literature wise, but I think dmeek's stab at 10 ohms is probably correct since the first band is brown and normally that part of the Zobel network is a low value resistor.
                  VH: Different site but could be useful reading to you. Read Teemuk's entries in this posting - Randall RG140 - need information about a burnt resistor - or schematics
                    The model appears to be, or similar to RG50-112. That model has the pull switch. I can't find a schematic though.
                      Did you measure it? Is it close to 10 ohms?
                        Found the schematic
                        RG50 - Schematic.pdf
                          Originally posted by dmeek View Post
                          Found the schematic
                          [ATTACH]n985293[/ATTACH]
                          That IS pretty damn close !!!!!!!!!
                          im going with 10 ohm / 1 w !
                          THANK YOU !!!!!!!!!
                            If you just replace with the same power rating, chances are the resistor will fail again.
                              Still no report (post #11) as to whether the original part has actually failed or not.
                              It does look like it has been excessively overheated though.
