JJ 6v6s spare pins.
  • JJ 6v6s spare pins.
    Hi, can I use pins 1 and 6 as terminals, they show as no connection on the data sheet but I have a memory of being told previously that I shouldn't, wanting to mount the screen and grid stoppers if possible.
    No problem.Its been done on many Fender amps.Only problem I would think is if you use it with 6L6 type and then wanted to use EL34's,as they use pin 1 to connect supressor grid to the cathode.
      Thanks, I wired the screen dropper via pin 1 and grid stopper via pin 6, all's well.
