inside MXR dynacomp!!!???
  • inside MXR dynacomp!!!???
    Hello
    I need to see some pictures of inside of a MXR dynacomp from 70ís.
    From the pcb and the switch and all.
    If you have some pictures please let me know .
    Thank you all in advance
    What do you need to know?
      Mxr
      I need to know where to connect 3 lose wires
      Orange yellow and gray are lose.
        Jay,
        I've got mine open in front of me (pots up, PCB standing straight up). The orange wire runs between the far-left terminal of the left (Sensitivity) pot & the upper-right solder blob on the bottom of the PCB, and the gray wire goes to the center terminal of that same pot & the lower-left solder blob on the bottom of the PCB (no connection to the right-hand pot terminal). The yellow wire runs from the same Input-jack terminal the other yellow (switch) wire connects to, to the right-center solder blob on the PCB bottom. For reference, there's also a brown wire from the upper-right of the PCB to the switch.
        Let me know if you need the PCB connections and/or a pic (which I can E-mail to you). My unit is red, w/lower-case 'dyna comp' lettering.
        Ray
          Thank you
          Ray
          Thank you so very much.
          By your help my MXR works now.
          Thank you
            Jay,
            No problem at all - glad to help. I'm actually happy I opened mine up, as both the box packing foam and PCB-insulating foam were quite deteriorated, and the battery was nearly dead! I better check the other ones now too...
            Ray
              hello-
              I'm a newbie and need similar help I have an 80's or 90's MXR M-102. I need a picture to help me out. Do you still have the picture mentioned above 4 yrs ago?
                anyone with a 80's 90's dyna comp photos of the inside?
                thanks
                  Check out Monte Allum's Mod site... if memory serves he's got pix of several different iterations of the dyna comp pictured so u can order the right parts to mod whichever version you happen to have
                  Hey you... Yeah you kid... Ya wanna buy some "Magic Beans"?
                  Girls Out West Busty lesbians masturbate ?????? ????????? ???????? ????? ?????????? porno gay audio latino
