I just got a 1975 Phase 90 but the inside has all the black foam melted on the parts.Can I use a metal razor blade to clean it off ,or can I short it outif I touch the wrong thing
Cleaning inside of Pedal??
how about an old stiff bristled toothbrush? (Maybe if you were REALLY careful, you could do it, but) metal on metal or metal on the PCB fiberglass doesn't sound like the best idea (although I'm sure you won't be attacking it with full force). Rubber eraser on a pencil, maybe? (small controllable point, "grabby" tip) Maybe alcohol with the toothbrush (alcohol can be good for cleaning, plus it evaporates). With water I'd be worried about it soaking into something (carbon comp Rs or whatever).
