Finally went back to an old hard drive an recovered some pass emails.
here is the schematic for late 90s ehx microsynth
nosaj
EHX Bass Micro Synthesizer
Originally posted by Mark Hammer View PostI've been "repairing" one for the last year and a bit. I had it running properly about February last year, but when I went to reassemble the unit, something either shorted or fractured (damn you with your solid-core wire, EHX!!!). Exasperated, I needed time away from it.
That said, the initial repair would not have been in any way possible with this drawing from my good buddy Stephen Giles, in England, who used to work as an accountant for EHX there, and seems to always have arcane pieces of technical info about their products. The schematic can be gotten in many places. Knowing which chip is which is a whole other kettle of fish, though. This drawing sorts that out. It is for the big-box guitar microsynth, but it only differs from the bass unit in terms of a few component values; e.g., for the filter.
[ATTACH=CONFIG]57762[/ATTACH]
nosaj
Leave a comment:
Leave a comment:
Here is the schematic.
DC power supply can be used, but operation may be unstable when output voltage is 24VDC.
30-32VDC is preferable.Attached Files
Leave a comment:
In accordance with the scheme, it is necessary to use a 24 VAC power supply (not 24 VDC).
Leave a comment:
Originally posted by Enzo View PostI just went looking at photos. Some are listed on Reverb for sale. One has a nice close up of the power adaptor. It says 24v DC 100ma.
I looked at several more listings and all said 24vDC 100ma.
Clearly the 9v adaptor is not the correct one.
nosaj
Leave a comment:
Leave a comment:
Originally posted by sunshine_bassman View PostI’ve got a vintage big box EHX Bass Micro Synthesizer that isn’t working right. The clean signal going through bypassed is garbled at acceptable preamp settings, meaning it’s either very quiet or garbled. When the pedal is activated, there’s just some buzz and no effected signal or clean signal passing through. What should be my first course of action in determining the problem? I’m using a Harmon 9v adaptor to power it.
nosaj
Leave a comment:
Open it up and meter the power jack, it it still 9v? Assuming it says 9v on the machine. Also check current rating.
Leave a comment:
I’ve got a vintage big box EHX Bass Micro Synthesizer that isn’t working right. The clean signal going through bypassed is garbled at acceptable preamp settings, meaning it’s either very quiet or garbled. When the pedal is activated, there’s just some buzz and no effected signal or clean signal passing through. What should be my first course of action in determining the problem? I’m using a Harmon 9v adaptor to power it.Tags: None
Leave a comment:
