Help with 1970s Guyatone Moving Box Flanger - SAD1024
    Originally posted by x-pro View Post
    Everything has to follow a pattern.
    And need a resistance between the emitter and the Anode​
    Thanks, do you mean the cathode? The schematic shows a 3.9k resistor between cathode and Q1 collector, I measure 4k.
      Rx-?
        Rx-?
        I have connected D1 anode back to ground, and Rx=0 ohm
        Edit: This is with IC4 and IC5 removed
          Raise one pin of D3, and check Rx again.
          If it is still 0, unsolder the chips one by one.​
            maybe C22 in short?
              With D3 lifted, Rx is still 0.
              I will start unsoldering !C1-4. How do I know which one is bad, what should Rx be?
                maybe C22 in short?
                I checked C22 with ESR meter and it looks good
                  I have removed all chips (IC1-6), Rx is still 0 (continuity between DC rail and ground)
                    Q3 remove
                      Unsolder the chip, apply 18 V to the power socket and measure the voltage between emitter Q1 and anode D1
                      All ICs removed (1-6), voltage at Q1 emitter is very small (~160mV), voltage at D1 anode is 0V. Q1 runs hot quickly
                        Is Rx equal to 0 or is there a resistance? In both directions, if the probes of the device are reversed.
                        • #27
                          Rx is definitely 0 ohm, and there is continuity between IC1-4 pins 4 and 8 (V- and V+)
                          • #28
                            Maybe you soldered something badly and shorted it out?
                            • #29
                              delete Q3, C26
                              • #30
                                Connect the LED like this, but remove transistor Q1 for now. The brightness of the LED will indicate a short circuit. As soon as the short circuit is gone, the brightness will drop significantly or not at all.
