I hadn't tried it til now, but you're right - it doesn't seem to be working. I've also noticed that the page increments I set for it in the Admin Panel aren't being used.
-tb
"If you're the only person I irritate with my choice of words today I'll be surprised" Chuck H.
Side issue: On the Repairs and Maintenance forum there are half a dozen or so Sticky threads. This reduces the number of active threads you can see. This wouldn't be so bad except when you go to page two and every other page below, the same Sticky threads take up half the page. Do the Sticky's have to appear on every page ?
WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel. REMEMBER: Everybody knows that smokin' ain't allowed in school !
Wanted to give this a quick bump. I tried to set the default posts per page to 20 and 30 again today, but it still would not save the change.
I tried it and got the same result. The change won't stick, it just goes back to 'use forum default'.
