$8.50 Chinese wraparound bridge fits PRS SE!
  • $8.50 Chinese wraparound bridge fits PRS SE!
    I have not strung it up yet but it does fit the stock PRS studs. The ~$100 TonePros bridge requires the locking studs since it is about 0.040" thinner than the stock bridge- I was able to make up two shims but have not been able to find any more of the special brass washers. One note about the TonePros bridge and locking studs: for low action I have had to pull the stock bushings out and then drill the hole a little bit deeper with a 3/8" drill. Otherwise it can bottom out with the bridge too high. Here is a link to the listing:
    QZO Chrome Badass Style Wrap Around Bridge Tailpiece for LP Electric Guitar | eBay
    Steve Ahola
    P.S. The Chinese bridge fits better using the included studs which give a little more slack which is necessary. Those studs have the same metric threads as the PRS SE but the slotted top of the stud has a slightly smaller diameter and is flat rather than domed like the PRS. If that bothers someone they can order the TonePros locking studs which cost about $35 on eBay.
    P.P.S. People looking at the PRS SE non-trem models often think that the fixed-intonation wraparound bridge must be a problem. However I have never noticed intonation problems with those guitars. For one thing, guitars are tuned to a well-tempered scale so that the "right" note might be not be exactly on the fret. I may bend the strings just enough to make a chord sound right to my ears.
    The Blue Guitar
    www.blueguitar.org
    Some recordings:
    I've used a few of those on new guitars. I wouldn't let the price scare you. It's difficult to tell any difference between them, and components that cost many times more. They are taller than most wrap-around types by 2-3 mm which is a problem on most guitars if you use them for a retrofit. The saddles are tall enough that they can be reworked to match a tighter radius which you'll probably need to do on a PRS. (aren't they a 10"r?) Anyway, there's enough meat there to work with if you want.
      John: I noticed that some of the wraparound bridges make it very difficult to change strings when they are sitting right next to a humbucker. The fixed-intonation "Z" bridge on the 2014 Melody Maker doesn't have that problem- the engineers made it very easy to replace strings.
      One question... to replace the MM bridge with one of the adjustable intonation bridges from China or from Tone Pros I would want to use the TP locking studs. The Gibson studs have 5/16 24 tpi threads. Do you know if that is the same as the PRS USA studs? (I don't want to bother Tone Pros again right now- they have been very helpful and I don't want to wear out my welcome! )
      Steve
      The Blue Guitar
      www.blueguitar.org
      Some recordings:
        its all from China (or Korea or Taiwan) so compatibility isn't a surprise. Did you think PRS has American artisans hand carving everything out of sweet American materials? LOL at those prices they should...
          I haven't seen the new Melody Maker bridges. Are you having intonation issues? I never considered wrap-around bridges as being difficult compared to very many others, but an improvement would be cool.
          Steve
          IDK if the studs are compatible or not. Occasionally I'll do a repair or setup on a PRS, but never really paid that much attention. They're nice guitar's, but not anything I get excited about. I checked out the TP locking studs. The diameter of the locking screw seemed like a very weak link. When needed, using the thin washers as shims works well for me.
