Originally posted by agabinet
View Post
I did a modification of a G&L Telecaster-like guitar where I modified the Three Position switch (Neck, Both, Bridge, in parallel) with a Four position switch which added to the both position to the pickups being in series.
I also added stacked or concentric volume pots (500K) so each pickup could be individually adjusted even when in series or parallel. Use the volume pots as variable resistors with the pickup ground going to lug 3 of the pots. Make the pickups hot wire go to pin 2 (center) of the pots. Take the output (pin 1) from the pots to go to the selector switch. Now, make the tone pot a push pull pot with a DPDT switch where you can flip the phase of one pickup. I chose the neck pickup but disconnect any grounding to a metal case from the pickup wiring and connect it directly to the output ground after the selection switch.
What will this unique setup allow?
When two pickups are used in either series or parallel but out of phase. A slight variation of either pickup volume control (abut one tenth of a turn) will cause a variable notch effect to change the out of phase sound without needing any extra electronics. This effect is done totally passively. My guitar user of this wiring in the Atlantic City Area of NJ likes the wide diversity of this wiring and gets many comments from guitarist listeners about his unique sound.
Give it a try and let us know what you think about wiring it this way?
Joseph J. Rogowski
Leave a comment:
