Jazzmaster bridge breaking strings
  • Jazzmaster bridge breaking strings
    This Jazzmaster has a Mustang bridge on it and the 1st string actually contacts the bridge by the intonation screw and is breaking there. How do I correct that? Should I shim the neck higher, so that I have to lower the action at the bridge? Or else, I thought about putting a teflon sleeve over the string where it contacts the bridge, but maybe the string would cut right through it. I've never seen this problem before.
    Any help would be appreciated.
    Can you turn the bridge around so the screws are facing the neck?
    I think that's how they are on my Mustang.
      It turns out the strings were actually breaking at the tuning peg. Aargh! That's what happens when you don't get to talk to the owner of the guitar.
