You were right, it was wiring problem. In the K7 wiring plan it says, that the ground is soldered in the biggest part of the original k7 jack and the output on the middle one.
As the previous owner had some EMG´s on it, he also changed the Jack. And on this Jack it wasn´t the middle one for the output, it was the smallest one.
Thanks for the help.
Can anybody help me wiring my Dimarzio PAF 7 on a Ibanez K7
Originally posted by chile7 View PostBetween the ground of the jack and all conections i measure 5,95 kOhm.
Still not getting any sound.
What is the history of the guitar? What is factory original and what did you change?
Leave a comment:
Between the ground of the jack and all conections i measure 5,95 kOhm. I also measured the hot(red) and green wire of the pickup to see if the Pickups are alright. This are Bridge 6,71 kOhm and Neck 6,91 kOhm. Still not getting any sound.Last edited by chile7; 09-07-2020, 06:58 AM.
Leave a comment:
Originally posted by chile7 View PostThe Pickups have Neck (6,91) and Bridge (6,71) resistance.
I think the Pickups are alright?
Do you get 0 Ohms at the output with vol control at zer
Are you sure you soldered the correct 2 lugs of the jack?
Do you have a spare phone plug?Last edited by Helmholtz; 09-06-2020, 09:59 PM.
Leave a comment:
Leave a comment:
Originally posted by chile7 View PostAlright, now i have a DMM. Which settings should i have on the DMM and where should i put the pins of the DMM on the Guitar?
https://www.sciencebuddies.org/scien...ingamultimeter
Leave a comment:
Leave a comment:
Originally posted by chile7 View Post@heimholtz ich denke wir können auch auf Deutsch schreiben. Danke für deine Hilfe erstmal.
Du möchtest sicherlich ausschließen, dass der Input Jack defekt ist. Diesen habe ich durch einen anderen ausgetauscht und es bleibt das Problem. Kein Sound
Let's switch back to English allowing others to follow and participate.
Leave a comment:
Leave a comment:
Is it dangerous to manipulate that without being an electrician? And what jack do you mean?
Leave a comment:
I don‘t have any components to measure a resistance. What do i need in order to check that out?
Leave a comment:
With vol fully on, what resistance do measure between the terminals of the jack?
Leave a comment:
Hello, im new to wiring Pickups to a guitar.
I have the wiring instruction for the Ibanez K7 from the Dimarzio Website and i did it that way, but i´m not having any sound coming out.
Can anybody help me please.Attached FilesTags: None
Leave a comment:
