Switch Coil Splitting to Outer Coil (Top coil) in Neck Pickup?
  • Switch Coil Splitting to Outer Coil (Top coil) in Neck Pickup?
    I'm driving myself crazy with this one. I have a PRS Custom 24 SE (1 Volume, 1 Push/Pull Tone, 3 way blade) that I'm putting a Dimarzio PAF 36th Anniversary in the Neck Pickup.
    Based off these instructions I believe I can tap the inner coil by soldering the red & green to the push/pull, and the white to the 3 way blade, and the black to ground.
    How can I switch these around to the tap the outside coil?
    Thanks!
