Hi all,
I'm working on building a loaded pickguard from scratch. This is the first time I've done anything more than an PUP swatch. I have learned a lot and I'm nearly at the finish line to put it into my Strandberg.
However, I've run into dreaded hum.
While testing my wiring, I notice that I have what seems like a ground loop hum. I am 99% confident that my solder joints are good and that I only have 1 single path to ground from each component.
I'm not sure if I have a ground loop or if I am getting this hum only because the guitar is outside of it's faraday cage home inside a shielded cavity -- and it's not actually grounded to the trem claw yet.
In a nutshell, my question is:
Is a 'loaded' pickguard as quiet as it will be INSIDE of a guitar while it is OUTSIDE of a guitar?
When I touch the output jack or the active lead on the switch(es), the hum goes away -- so it _seems_ like a ground loop.
As a newbie, though, I'm not sure if this is "normal" for when a pickguard is OUTSIDE of a guitar?
Here is a video showing the hum and some troubleshooting "touches":
https://www.youtube.com/watch?v=3iW1mfqPucg
Some more troubleshooting data that I do not have in the video:
- When I turn the volume pot down below 10, starting at 9 the hum gets significantly louder. It's much quieter when the volume pot is max'ed. Video here: https://www.youtube.com/watch?v=USwcP8RQzRA
