the general question i am asking is, how much a pickups character would effect the sound on an instrument thats inherrently deeper than a standard guitar? the background information is below
ive started making an instrument similar in concept to a bass VI (6 string bass, but tuned E to e like a guitar, just an octave lower.). it will have a tele style body and tele bridge, so i will be making a tele bridge pup, but with longer magnets (20mm). there will be a p90 style pup in the middle and a neck pup, which i havent decided on (possibly another p90).
i want the instrument to be able to sound articulate enough to play chords even in the lowest octave. its mainly for a trio with a guitar that uses a slide mainly, so not cutting enough for a 5 piece metal band but significantly more articulate than a bridge pup on a jbass for example. i will use it for more traditional bass roles as well, but i will use a switch to put pups in series to get more inductance for a deeper sound.
my question is how should i plan on winding the pups? with guitar usually less winds will give it more top end, but being an octave lower than a guitar i doubt there will be much top end (speaking guitar spectrum), and winding a bit more to drop the resonant peak to a level that tends to be more present may be a good way to do things (atleast for the bridge and to a lesser extend the middle position).
using a tele ashtray style bridge the bridge pup is close to the saddles (closer relative to the scale length as the scale length is 30.5" on this as opposed to the 25.5 of a standard tele) so that should pick up quite a bit of the upper harmonics. i think the bridge pup is my main concern. i can mix it with the mid pos p90 for a fuller sound, but i know that i wont have an issue getting a full sound. because of the string spacing being 54mm at the bridge, i will be makign the middle p90 (and probably the neck as well) from timber, but they will be close to p90's in dimensons and will be the same poles and magnets)
the issue i feel is that i havent actually played a fender VI or similar, and dont know what to expect from the sound. i just like the idea of playing like a guitar or bass on the same instument (and it would really work well with the band im in atm)
edit: i expect to end up doing some tweaking, but i want to start as close to the mark as possible.
thanks for any help
thanks for any help
