I don't need all these tests. I know the mismatched coil thing (one coil with significantly more turns than the other) works, and works well. So well I have yet to sell a humbucker without this feature.
Coil offset for neck pickups?
Well, there are positive things about equal wound coils as well, its not something that should just be ignored. Both my early patent pickups '62 and '63 are equal winds as well as a '60 PAF I repaired. After all it was INTENDED that these pickups be equal winds, they were just too lazy and sloppy to get it right until those years. My Patents sound just like the real PAFs they are, they have some differences in tone but not bad differences, just different. The unequal winds thing gets a little too mythic for me sometimes, you should really explore both and use each for certain applications. If you take apart all the top selling big ticket PAFs that are sold the unequal winds are minimal if at all. My Holmes are equal winds. Too much offset doesn't sound that good to me, but then it depends on what metallurgy you're using too.http://www.SDpickups.com
Stephens Design Pickups
I agree with Dave. Sometimes you want equal winds, sometimes you don't.
Equal winds are good for a neck pickup when it's a bright guitar, or something with a floyd, but mixed coils is good for things like basswood bodies where you don't want something too boomy, and bridge pickups sound good as equal winds for more mids.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by Possum View Postyou know, traditional humbuckers actually AREN'T humbucking. Seth Lover knew that. You will only get true humbucking if you make both coils slug poles or screws poles, with slugs and poles together the pickup isn't getting equal extraneous noise coming into both coils. I read a more recent Lover interview and he realized that and though the sales guys who wanted adjustable pole screws were a buncha dummies :-)
Originally posted by Zhangliqun View PostI don't need all these tests. I know the mismatched coil thing (one coil with significantly more turns than the other) works, and works well. So well I have yet to sell a humbucker without this feature.
yep. And you would bias a particular coil based on what you want to achieve with the tone....i.e., fatten it up vs. adding sizzle/enhancing the high end.
I just wanted to hear some opinions and reasons why folks do what they do.
Originally posted by kevinT View Postyep. And you would bias a particular coil based on what you want to achieve with the tone....i.e., fatten it up vs. adding sizzle/enhancing the high end.
Originally posted by kevinT View PostAnd you would bias a particular coil based on what you want to achieve with the tone....i.e., fatten it up vs. adding sizzle/enhancing the high end.
