In my system you are totally dependent on the fit of the drill press quill to the main casting. Any wiggle-room there and all bets are off as to where the drill will go in. I've had to modify the presses I use with delrin screws that come in from two directions, 60º apart, through the casting and push the quill to the back so that there's no wiggle room at all.
The pin is carbide, it won't wear but the registration holes in the aluminum will wear out eventually. Luckily the person I was making these parts for has just retired so I can retire the tooling as well now.
