Here's one I made from a Grizzley lathe. I just looked and they don't sell this one any more. I think I paid $40 for it. The counter came from ebay and the delrin came from the scrap bin at the local plastic company. I've since taken the tail stock off. It works just fine without it.
Schatten winder motor
Hey Bill I reckon those fan motors are great for the job, they're really quiet, plenty strong enough and I think most blokes are happy to wind between 500 and 1000 rpm anyway. I hooked one up to a one of those 400 watt Light dimmer switches and I was pleasantly surprised in how smooth and linear the controller was.
The switch was a bit pricey but worth it.
regards
WalI know the voices in my head aren't real..... but man, sometimes their ideas are just brilliant.
Yes Walcen
You know I was thinking the same thing.
Slower rpm you can see the wire lay down better (I suspect) which will aid in the winding technique.
I was also looking to use a dimmer for speed.
I am a bit surprised that there aren't more of this type being made.
Side note: my instant email notification though checked isn't working??? Hmmm
Bill
Originally posted by Mystic View PostHere's one I made from a Grizzley lathe. I just looked and they don't sell this one any more. I think I paid $40 for it. The counter came from ebay and the delrin came from the scrap bin at the local plastic company. I've since taken the tail stock off. It works just fine without it.
I remembered this winder and was hoping they still made that lathe, since you can shorten the bed.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by Bill Scheltema View PostWell here are a couple of shots of the motor I plan to use.
You can see the osc. mechanism out back, for now I think I will leave it out of the equation and do straight on hand winding in order to get a feel for the whole process.
Originally posted by Joe Gwinn View PostIt's very useful to be able to slow down almost to zero speed. This motor looks to be an induction motor, which may not be controllable enough. I'd do a motor test before building a winder around the motor.
regards
Originally posted by walcen View PostThat's a good point Joe, so I ran a test with three different fans using the said dimmer and found that they all behaved remarkably well, that is to say that they all slowed to a crawl and achieved top speed although I did notice that with the smaller of the fans actually stops, and makes less humming noise at slow speed. So the smaller fans motors may be the way to go because you really don't need that much grunt to wind pickups.
Originally posted by David Schwab View Post
One of my ideas was to get this lathe as a basis for a winder ($126.13):
Amazon.com: SHOP FOX W1704 1/3-Horsepower Benchtop Lathe: Home Improvement
Thanks,
Steve
Originally posted by govtmule View PostI bought a similar lathe at an auction that I plan to use as a basis for my first winder. The speed control on mine does not slow the motor down to stop. It does have a soft start which is nice but even the slowest speed is pretty fast. Do you think I should look for another starting point or can I modify the speed control to slow the motor down even more ?
Thanks,
Steve
The solid answer to your question is yes you can modify it although not being familiar with that lathe I cant say how much work is involved and I'm no genius when it comes to electronics.
You may be able to install an inline resister or even an adjustable potentiometer to reduce the overall voltage.
If the speed control is a pulse width modulator it could be modified.
any techy would be able to help you with that.
regards
Originally posted by Joe Gwinn View PostWill the motor run on DC? If yes, a fullwave rectifier bridge between dimmer and motor may be helpful.
regards
Originally posted by walcen View PostFor all budding winder builders.
I hope this helps as I'm currently undertaking the task of designing a simple, easy to build and affordable pickup winder.
When the design and construction is completed I'll be posting all the detail but for now here's what I have so far.
here is the motor speed controller, it is easy to build in its kit form and it works well between 6- 32 volts, read the specs.
Bi-Directional DC Motor Speed Controller Kit
Also available in Aus.
Standard (High Power) D.C. Motors 11800 RPM - Jaycar Electronics
These motors will run Quite happily between 6-18 volts at 1/2 an amp with most wall power packs and spin at around 8000 rpm, I'm sure these would also be available in the states.
Or as I said, if you scrounge the motors out of Epson or Canon printers they work just as well but only spin around 3000 rpm, more than fast enough and real quiet
kind regards to all
Wal
As for being OFF TOPIC: I use custom wound coils in amp equalizer circuits using both tubes and transistors, and op amps in the qualizer circuit. I can't run out and buy small coils that are 3 Hys with 38 gage wire on a small bobbin, and a choke coils is kind of overkill extreme, if you can find the exact L, Z, rectance, etc. My new winder will have a way to wind small round open center bobbins. I can then make wah coils, etc. Nice info THANKS AGAIN!! I'll save my $450,, and probably spend $4200 in time and materials.LOL I bet mine works! Your remotoring info will be taken under advisement too!
