Originally posted by David Schwab
View Post
How do I wind a bright neck humbucker?
Originally posted by paulyy View PostVery nice! Thats kind of what Im looking for. Mine sounds good but theirs no pop or snap. Yours has the pop and snap that I like.
I like them bright like that.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by David Schwab View PostI was actually very surprised. I picked up a few kits to try out my winder, which I had just gotten.
I'm surprised too. A guy I know sells StewMac kits as handwound boutique p'ups and they don't sound like yours do, David.Pepe aka Lt. Kojak
Milano, Italy
I had made some straty-sound PAFs with 10,5 mm tall AlNiCo 5 rods in both bobbins, about 3,5 Kohm in one and 4 Kohm in the other bobbin of 42 awg wire.
The lower, unmatched outputs, and AlNiCo 5 rods seems to result in a clearer and brighter sound. Try this one.
Steel in the coils always seems to goes to a darker sound.
Belwar you should try the new Mojo baseplates, they're not the same according to David. Well, shit there's only one baseplate worth a damn and both AllParts and StewMac sell it, what else is there? Nothing. StewMac's price is ridiculous though, I buy very little from them these days..http://www.SDpickups.com
Stephens Design Pickups
Originally posted by LtKojak View PostDo you mind tell us how much did it measure, resistence-wise? Was it poly nylon wire from StewMac as well?
Originally posted by EFK View PostBTW David - is that a Gibson scale or Fender scale? It half sounds like a strat. Body wood? Neck wood?
That does have a lot to do with the twangy nature of the sound.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by NightWinder View PostSchwab uses Poly- I've been after him for near 4 yrs to get some P.E but NOOOO,lol.
PE is too expensive, and for what I do, I doubt I would hear a difference.
Most of the wire I use these days is Elektrisola and Essex. I like the Elektrisola stuff a lot. It handles nicely. I also have one roll from Phelps Dodge, that's 46AWG! I think Gibson used to get wire from them.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Just to see if I'm getting this right...
Would using, say, an FR4 fiberboard as flatwork material, but with the attached copper layer normally used for designing PCBs, provide enough metal in the bottom to boost the treble in the pickup output, or would copper, being diamagnetic, simply not work?
Any answer would be appreciated, including the "RTFM from your Electromagnetics I classes".Pickup prototype checklist: [x] FR4 [x] Cu AWG 42 [x] Neo magnets [x] Willpower [ ] Time - Winding suspended due to exams.
Originally posted by David SchwabThen you have neos... which is a fuzzy bunny wrapped in barbed wire.
A pci baseplate would give me a bright or a dark sound compared to metal baseplate?
http://www.sergiorosar.com/galeria/1024/015.JPG
Originally posted by Achiles View PostA pci baseplate would give me a bright or a dark sound compared to metal baseplate?
http://www.sergiorosar.com/galeria/1024/015.JPGPickup prototype checklist: [x] FR4 [x] Cu AWG 42 [x] Neo magnets [x] Willpower [ ] Time - Winding suspended due to exams.
There are several bass pickup designs that use copper clad PCB, even as bobbin material. The copper is thin enough that it shouldn't effect the tonality, while acting as a shield.
Core material matters too. That's one way that Bill Lawrence got those super bright, yet hot humbuckers. He also didn't use a metal baseplate. You can also use thinner wire.
But in general, just don't over wind them. Look at pickups like Filtertrons. Those are around 4 to 5K.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Didn't BL use stainless steel blades? Those are bright...http://www.SDpickups.com
