Originally posted by Possum
View Post
Reamer bit guide
Originally posted by Possum View PostIt sounds to me like his drill is too underpowered and losing power or is too low speed? Change your gear belt to the highest speed, put a little oil on the piece you're widening. I have a Delta drill press and do what you're doing all the time with an old drill bit and not having any problems, its just a cheapie from Lowe's. Go to Harbor Freight they're not expensive:
- Harbor Freight Tools - Quality Tools at the Lowest Prices
Originally posted by Zhangliqun View PostLooks all but identical to the one I have. The motor swivels out slightly in the back with a screw clamp to hold it in position -- I assume that's the means of tightening the belt. I have the gear belt already set at the highest speed per the chart under the lid.
You might want to try a slower speed then.
I haven't changed mine since I got it. I know it's not on the fastest speed, since it's better to drill metal slower and wood faster, and I use this for both, it seems like a good speed.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Good point, slower speed will have more torque, I forget what mine's set on....http://www.SDpickups.com
Stephens Design Pickups
Originally posted by Zhangliqun View PostThat tearing and chipping is what I'm running into. And yes, I'm using a drill press and a clamp. Nothing moves but the bit.
I do not force it in there, my little drill press just doesn't have near enough torque to try anything like that, it would stop dead while the belts continue rub against the shaft. So I just lower the bit with light gentle jabs into the hole to avoid abusing either the bit or the keeper, or the press itself for that matter.
And still I get this tearing/chipping so I think you must be right, Joe.
I think the chucking reamer is the answer.
PS, in case it wasn't clear, I am widening existing holes, I am not drilling new holes. Original size of hole is 1/8". I like the keeper holes just a shade wider in case the bobbins, baseplate, and/or keeper are slightly off in spacing relative to each other.
Interesting that the 1/8" bit I have cuts the steel like butter when making my own keepers but because my press doesn't have much torque, it will stop dead with the 9/64" bit, so I have to make the 1/8" holes, then widen them.
Using a reamer to go from 1/8" to 9/64" in one pass won't likely work, but a unibit step drill will do just fine. But don't forget the black sulfur oil.
Originally posted by Joe Gwinn View PostBut don't forget the black sulfur oil.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Another thing, push the drill bit WAY up into the chuck so you have the minimum amount of drill bit sticking out, this will make the bit effectively shorter and more stable. If you just have a small grip on it and the bit is allowed to be long and not well gripped that would cause problems too. When I drill my keepers on my mill I always use the minimum amount sticking out to get the job done....http://www.SDpickups.com
I tried drilling with an 1/8" end mill, I didn't like it, it really stressed the machine alot, though it didn't wander much. Not really a good idea...http://www.SDpickups.com
Originally posted by Possum View PostI tried drilling with an 1/8" end mill, I didn't like it, it really stressed the machine alot, though it didn't wander much. Not really a good idea...
There are also end mills designed for drilling. The tip is pointed, not flat.
Be aware that drill chucks cannot get a very secure grip on end mills, which are too hard for the chuck jaws to dig into. The shanks of twist drills are made slightly soft, precisely so the chuck can grip them securely. Use end mill holders for end mills.
The other danger is that if one tries to mill moving sideways on a drill press, the side loads and pulling forces will often unseat the chuck and it will chase you around the shop as it spins.
The bad part about having flying machine parts chasing you around the shop, is that they'll usually catch you. They're fast.
I agree with all of the above: To drill steel, your drill press should be on the slowest speed it will go, with the belt tight. A sharp bit, short length, cutting oil, and the part held in a drill press vise or clamped down. It takes horsepower to peel steel chips. That means more downforce on the quill arm, and more resultant twisting of the part.
Originally posted by Bruce Johnson View PostTo drill steel, your drill press should be on the slowest speed it will go, with the belt tight. A sharp bit, short length, cutting oil, and the part held in a drill press vise or clamped down. It takes horsepower to peel steel chips. That means more downforce on the quill arm, and more resultant twisting of the part.
