i have a 70s guild humbucker in right now that got some issues; it's wired with a separate wire coming from each coil, two conductor with shield wired to ground at the baseplate. essentially seems like a four conductor wiring, but when wired up the pickup is really low output, noisy, and thin compared to the matching humbucker in the bridge.
each coil reads about 3.5k resistance. the magnet strength is good. when wired with coils in series, total resistance is just about 7k, a hair under. i've tried several different ways of making the series connection for the pickup, and also wired the pickup directly to the output jack to take the other controls out of the equation with the guitar.
any thoughts on what i could be looking at? if i were seeing a significantly different resistance reading i'd think the pickup was opening or shorting, but it seems like everything is in the correct range, and i'm not sure where the issue really is at this point. it does look like it was rewound or at least toyed with at some point-- there are trimmed leads at the solder tab on the baseplate-- but i don't know any details. because i don't know what's going on w/ the pickup internally, i don't even know which wires (there are white and red off each coil) are the start and end positions for each coil, or if they're flipped...
any help appreciated
brian
brian
