Originally posted by David Schwab
View Post
something like - ( -) = +
In our particular case there's even another turn... or one less
You wire the PUs out of phase to cancel hum,... that's the first common step...
since the pickups sense the string from opposite sides, that's all you have to do, the out of phase wiring is already fitting (since the signal detected at each side of the strings is out of phase with each other). You don't need to have different magnetic poles on each side of the string. Doing that is alright for the regular humbucker, but not for our "one coil on each side" humbucker...
If you wanted to use different polarities to face the strings, then you would get again an out of phase signal...
or, you would need to sacrifice the hum canceling thing and wire them IN phase... something like slicing the coil of a single coil in two, and putting one half over the strings.
Cheers,
